pete,
if you wanna cover the cost of 2 missed weekends (the best paying shifts of the week) so that i can come along on this awesome road trip (which i was embarking on straight after a 10 hour shift) i would be more than happy to do so.
much love,
dave.
so the 2 for 1 tuesdays at the "house of pleasure" still dont pay as much as your weekend regulars?
I thought for sure that was a great idea. LOL
lol, those tuesday tightarses? they barely have enough money to make a phone call.
tight arses, I was told i would have to pay extra for them :):):worship:
ill give you a discount sweet cheeks. :O
I thought the 2 for 1 was a winner for sure (except for the mother daughter combination)
you serious? mother daughter is the best combo ever...
... well, second to sister sister.
That turbo you have there Abe is not a XR6T rear, as they have 'Ford' Stamped on them, not garret.
I was talking about the flange pattern, not the actual rear housing.
I emailed HPIAB today about some prices on some items. Haven't received a reply yet, could anyone tell me a good place to get copper washers from for braided lines, and a turbo manifold spacer. I am thinking ATS, maybe?
I went with the slightly bigger rear housing as that was what about 75% of people are recommending in the Forced Induction thread, and also a few tuners i have spoken to. As it is also going in my daily, it gets driven to and from work, so the speed limit is 60-100kmph, so i saw no point in having a turbo that spools too early. But if my engine dies, it has given me some head room for when i rebuild the RB25.
Shame i wasn't online to see your photoshop Andrew, serves me right to attempt doing my tax via etax.
On the topic of dished chromies..how about these bad boys?
twink... no. those will look awesome on an old mustang, goat, charger, or anything similar... but an import...?
amazing how quickly the level of conversation drops on here LOL
lol. throw some flange and rear housings into the mix and watch the boys go crazy...
... mmmmm... flange.
Edited by scandyflick
Some pics of new acquisitions for my new toy.
Plus a CF intake tube yet to arrive. Plus LEDs for all internal lights, parkers and number plate lights. Plus lots and lots of little bits and pieces.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
