u do realise that a NA engine has more torque due to the fact it dosent have forced induction to get everything going?
That i do and would work in theory......but i would still like to compare your torque figures with mine.....regardless anything else....
http://www.news.com.au/story/0,27574,25857567-29277,00.html
on another note....Australia's oldest hoon driver bahahaha
Edited by Krishy
Despite being able to immediately impound the car under anti-hoon laws, the driver was allowed to continue on his way. He has been ordered to take his car to a police station tomorrow, where it will be impounded.
"The speed he was travelling at ridiculous.''
Yet they let him continue driving to his appointment ... even when he showed no care for the 160kph+ speeds he was doing? :pirate: What if he'd killed someone after the cops let him go???
in the report the old guy even confessed to driving even faster before......he said lucky you didnt catch me before....i was going faster....
I mean seriously WTF is wrong with the police....i bet you if it was a 18 year old kid behind the wheel then he would be behind bars and car either impounded or crushed......talk about the cops always having double standards.....
Mate, I've seen 50+ year olds driving hyundais hooning thru traffic and they get away with it day in and day out.
Altho I did see justice last night at Regency Park. P-plater with mates in his "taxi" Falcon edging me to race him at the Regency Rd lights heading north on South Road. I gave it a quick squirt right up to 70kph (speed limit) ... 10 seconds later they screamed past me at about 100kph. The traffic cop (whom I noted was there earlier when I drove past) on his bike was hiding on the other side of the road, pulled out, gave chase and they got nicked :pirate: Yeah, I set them up a bit, but they didn't need any encouragement anyway. :P
how was everyones day?
Same as yesterday really, so-so. Woke up at 11, had breakfast, moved a garden shed, started surfing the forums, watched the chasers war on everything, and played some cod5 coop with a mate. Tomorrow i am back at work, i find that i am rather bored unless i am going something...such as working.
How about you?
only na nissan engines worth driving imo are v's over 3.5 litres.
wut?
yes solid lifters, lower emissions levels , and if its a series 2 it has higher torque cams in it. the output goes up to 206kw as well
  • RB25DET - twin-cam turbo (T28 Turbo) (245 to 250 hp and 319 N·m)
  • NEO RB25DET - twin-cam turbo (206 kW (280 PS) @ 6400 rpm, 362 N·m (37.0 kgf·m) @ 3200 rpm
________________________________________________________________________________
Released in 1998, the R34-series Skyline engines have a big emphasis on reducing emissions.
The existing RB25DET was reengineered to NEO specs, which apparently produce around one-tenth of the CO, HC and NOx emissions levels allowed under Japan’s 10-15 test mode. Further changes include a ball-bearing turbo, slightly larger intercooler, free-flow exhaust and revised ECU (which allows up to 10 psi boost). revised in late 2000 bringing extra torque (probably through a bit of extra mid-range boost).
Not sure where the RB25DET engine torque figure listed above came from, but it's actually quoted by Nissan as 30.0kgm at 4800rpm - just under 295Nm.
If one were to take the RB25DE and RB25DET minus it's turbocharger and compare the torque output, the naturally aspirated RB25DE would indeed make more torque, due to the 10:1 vs. 9:1 compression ratio. Now add the turbocharger back into the equation, where it rightly belongs on the RB25DET, and 230Nm vs. 295Nm tells the story.
Correct, however an N/A 25 will never make more torque than a turbocharged 25. Hence my "what the!?!?!" :)
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
