oh dear, last nite was a hoot
dave, hows the random body parts that got slammed into the door frame / pillar of my car?
should upload a few photos when i get my camera out the car......wasnt overly muddy but we found a good spot to go through. Even the cop that rocked up was chilled
So in light aircraft back here then? Errmm...No thanks :happy:
i prefer to call them dingy's in the sky
anyone know the causes of hard to start rb25? its cranks over but takes 5-6 times to slowly get running.. once its running if i turn it off then back on its fine..
its like only once its been sitting for a few hours!?
any ideas?
I have the same problem as well....so far cannot work out what it is arrgh
Next time you get on a plane flight and the guy next to you is an a-hole or the lady won't keep her kids coralled from kicking your back .... follow the instructions below ....
What to do in a flight when you have an annoying passenger seating next to you ...
1. Remove your laptop from the briefcase;
2. Open the laptop slowly and carefully:
3. Turn it on, as well as the sound;
4. Make sure that the passenger next to you is looking;
5. Access the Internet;
6. Close your eyes for a few moments, open again and look up to heaven ;
7. Take a deep breath and open the site: http://www.myit-media.de/the_end.html
8. Observe the facial expression of the passenger seating next to you.
Since i fly a lot for work i will keep this in mind LOL
Just putting the word out there that if anyone is interested in coming to Ministry of Sound Trance Nation to HQ next friday please hit me up for some tickets as its $30 on the night and the tickets are $20....cheers
BTW... If you want to prove a point N/A wise... You should do it in a 7.4L v8 or something. There is nothing that can be proven in a 2.5ltr 6Cyl N/A :down::P
I would be a bastard and say "rolls royce merlin' but theyre super charged so i have to settle for Rolls Royce Meteor
rd&l
-D
lol, it was a riot. lookin forward to the next outing. got a few killer bruises from that door of yours.
Life Story entry #336
Loaded and delivered some of the jarrah flooring that I purchased yesterday and today. Oh boy, did I bite off more than I can chew! I'm barely halfway thru it. Getting the rest of the 180m2 of flooring next Sunday (after dyno day).
I've still got splinters in my hands :rofl:
This week I gotta order the floor framing materials.
How about wearing some gloves?
Attn scandy;
How much was your turbo rebuild and hiflo and where did you get it done again? Looking at buying some N1's that are in need of rebuild cheap and sussing my options if its even worth buyin haha
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
