The answer to all your questions there are, no idea :(
I will be pulling it out when i put the new turbo, and ecu in...so 1-2 months time. As for cost, no idea how much they go for, plus i may hang on to it for regency issues. Power wise...Krishy i think is still using a stock series 1 afm, so about 220rwkw, maybe a bit more.
very very nice power figure Dave specially when its untuned.....R33 AFM's are good for about 250rwkw's and that would be most likely maxing them out at that point....i am going to get the car tuned with the stock AFM and see how much we can squeeze out of it before swaping to a Z32....i am only making 211 atm.....Saturday should tell :(
can someone help me out ?
i bought an engine off this forum which was apparently working etc etc and had been pulled apart and put back together professionally but after putting it in the car and
being compression tested it has low compression (waiting on exact figures).
the guy i got it off said that when i picked it up it had a timing belt on it and the timing was set to tdc but ive come to find that it was missing idler and tensioner pulleys , not to mention
it was also missing oil seals around the back of the cam pulleys and its missing bolts off the intake manifold.
it also had heaps of missing coolant lines...
what can i do ?
ask for my money back ?
ask him to pay for repairs ?
shit mitch your situation is getting worse day by day mate.....well you can give the seller the 2 options and see what he says in regards to it....goodluck with it mate....just cant wait to see your ride back on the road
you and me both man !
so over this crap
but i got some good news this morning
got accepted into tafe to study Cert II in Automotive Mechanical , starting jan next year :)
makes me think about my power figures....when i first got my car tuned..it still had its n/a fuel pump and reg...but had a early darkhalf rechipped ecu (before realtime) and rb20 redtop nics injectors...it pulled 175.4kw at the treads..but leaning out big time in the top end....this latest tune it had a bosch 040 pump and a vlt reg...but only pulled 150.....my first tune it was still using the same AFM as when the car was on lpg n/a and had it blown apart a few times.....i dont get it....when it was first tuned....it had the same fuel filter and plugs from over a year previously....me dont know...me too little
Dave, get in touch with luke
he still has his GTR pump, and glenn has a Z32 that he'll no longer need, solves both problems then
Correct, got a nice GTR fuel pump sitting here with your name on it. And Glenda has a Z32, problem solvered
messing around with the valve timing without knowing what you're doing can definitely have an effect on compression.......very easy to dial in and dial out compression by varying the valve timing slightly.
Might be running like crap though but if it's not running yet, be careful of any valve to piston contact
what can i do ?
you can ask for anything but your chances of getting it are minimal since it was a private sale so it's a case of buyer beware. that's why buying engine off wreckers will cost you more because they generally come with a start up warranty, so in this case you would have been covered.
I'm still waiting for you to clear the air about your claims about TT. you read the post that SLED made and yet you didn;t see fit to reply.
SCANDY;
S1 R33 and R32 AFM will support around the 210-220rwkw, but the SII R33 (pink sticker, 3 wire plug) will support around the 235rwkw mark. i wouldn't pay more than $100 with the plug for one. I paid $55+20 for the plug for mine and if you look around you can still find them for that price.
Edited by D_Stirls
how far down south do you live Daniel and how soon do you need it on the road?
Me or Matty could tow it up for you possibly.
if i had a winch on my trailer we'd be right..........but i dont :) and i dont hav my winch on the car yet (or a front towbar point for that fact)
nice. how much? :)
SCANDY;
awesome. cheers dale. ill see what i can find.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
