Which one have you got (M or LS)? How much of the reo had to go?
PM sent
Having a poke around, seems to be a real pain trying to find an affordable FMIC that doesn't require modification to the reo (which is apparently defectable and could result in insurance claims being voided :down:).
I've heard mixed reports from people on the JustJap stealth ones (some say they got it to fit, most others say it requires modification - including justjap). I've seen some posts say that particular Greddy FMICs fit without reo mods, and same for the Blitz FMIC kits, and AVO FMIC kits - but I always seem to find other posts contradicting it. Either way, it's enough to drive you nuts in an attempt to stay within the law.
That's the only thing that's stopped me thus far is the reo needing modifcation!
why buy an off the shelf kit then?
Just jap cores are cheap to buy and are just as good as expensive brand name ones
then all ya get done is get some pipe work made up, so nothing has to be modified
if you are careful how you mod the reo you will get away with it. i needed to take about 15mm off the bottom to get mine to fit. rather than just take it off the centre i trimmed it off an even distance the whole way along, and then painted it. It looks completely standard, the only way you would be able to tell is if you had two side by side.
+1 on that, cutting up the reo or bar doesn't jump to mind of things I'd like to do.
Also, was quite amazed when ringing around at tyre prices today. KU31 in 265/35/18
Wheel Worx - $275
Adelaide Radial - $305
Bridgestone - $325
Beaurepaires - $410
I knew Beau would be shit, but wtf!
Wheel Worx - $275
Bridgestone - $325
Beaurepaires - $410
did you forget to ring adelaide tyrepower?
ok, I got a question, Bomex body kits for 2DR R34. cool or gay ? Im looking at one for my car, found one cheap $500
front bar, side skirts like the top car, and rear bar , new in gel coat
i reckon the front bar and the skirts are cool, but the fake diffusers on the rear bar is a bit over the top
popped by andrews place before work this arvo, and went for a quick spin in munro's 35, f**k those things are awesome. relentless acceleration, and it seems so effortless...
... how much does a left testicle sell for these days?
he also seemed to find my car rather tough, quite a compliment from someone that owns such awesome machinery.
<snip>
sorta glad i went with 17 over 18, prices are retarded for 18's.
bit of left field here, but does anyone have hook ups in the truck accessories game
need some rubber mudflaps for the patrol, to cut down to size (the gay nissan plastic ones that have all the metal support framework rust over the years decided to break on the weekend - seems they dont like getting buried in sand and then pulled at funny angles when the truck is extracted)
Anyone know where I can get bushes for the rear upper control arms and tie rod ends? My mechanic rang nissan who told him that they only sell the rods with the bushes O.o
Also after a fuel filler cable/handle set with mounting brackets
-D
Edit - only posting here because the work is going to be done tomorrow
Speak to Shock Systems on NS.com, he sells all the bushes, and he's pretty cheap and in Adelaide.
thx for the heads up, but it seems like he only does web based stuff ;\
ideally i'd like to find someone in adelaide where we can get the bushes tomorrow and do the install
otherwise i guess i'd have to deal with the web so it'd be worth dealing with him i guess
its a shame he has no mob number
-D
When i did my FMIC install, the only Reo mods i had to do was drill 2 holes...which is apparently legal, its only if you are cutting metal out that it is illegal. As these are holes that bolts are going through, it is replacing the metal that gets drilled out. Also the FMIC i used, uses the stock piping, only had to mod the front bar a bit for the piping.
or more images here :P
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
