They will 15x6.5 so are the wrong size since he is looking for 14's
Adrian of you are looking for 15's then i ahve a set of light weight 5 spoke 15's that you can have for $300.
hey do they have tyres? and whats the sizes?
yep Breaking Bad and Dexter are 2 of my current faves ..... along with Weeds and True Blood! Can't wait for Californication, Chuck and Dollhouse to start back up soon too.
season 4 ep 1 of dexter has me hanging on the edge of my seat !
They do but only 2 have tread and the other 2 are hard because they are fairly old. same size as the factory rims 15 x 6.5. the tyres are either 195's or 205's
Edited by D_Stirls
I've seen all the other shows you've listed but never heard of Chuck. ATM watching weeds, True Blood and Entourage as they are released each week. s04e01 of Dexter was good but a little predictable.
I'm really hanging out for the final season of Lost. I just re-watched all 5 seasons to remind myself of the storyline and all the plot twists.
hey didnt really know where to put this but does anyone know why i can only send 1 private message then if i try to send another it says there is an error and that i have to wait till a certin time and its like 8 hours away or something like that. is it coz i havnt made many posts or what ?
Edited by -pumba-
^^^ no it is flood control to stop the spammers who were consistently spamming SAU for a while there. I believe if you donate to SAU (go to 'purchase paid subscriptions' (or something like that) in your user cp) it is lessened. Even I have a limit of PMs I can send per minute these days - it used to be unlimited for me :)
I paid the deposit on my new car today :) .... and NO, none of you have seen it .... the 2 I were looking at both got sold on me :ninja:
I hope the mechanical check holds up tomorrow - but it darn well should on a car with only 27,000km on it!
Got any pics Dale? Looking for a more "fitted" rim for my 31, has some sort of 4 stud Nissan rims on it with a very high positive offset.
%*&^! beautiful
Presumably one of the first in Aus too hey.
that thing will grow in value down the track!
WANT! however the bank probably wont agree with me. nor the missus... blah
some lucky chump will land it
Reckon I might have found the reason why my Stagea is running so poorly.
The FPR hits nearly 60psi on start up/warmup and makes a slight whinning noise, then drops to barely 30psi after 10 seconds or so and the whining noise goes away!
I'm swapping the FPR tonight. If the car runs better, then I'll know its the FPR.
wasnt that the malpassi one ruby ? Ive had them die a few times on the RB30 and now keep a spare wreckers one in my parts box..lol
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
