my dash if everyone hasnt seen yet..
Looks good. What's it had done exactly, where, and how much did it cost? From what i can see, carbon fiber, and some form of re-trim - unless that's a dash mat.
Black Velour with double red stiching, which matches the Nardi :P Also helps with windscreen reflections when driving.
Place called Winner Products on main tce at Richmond. Price was $550.
Edited by Luke_ENR34
Actually i do have these pics that he sent me when i first enquired:
Keeping the 34 because i realised i kept talking myself into wanting to sell it, had no real reason for it. I mean shit, you're only young once!
oh jesus. narbofag pipe work. so nasty.
now need to get a helmet......anyone know of a good cheapo one thats approved for the track
i think i may have posted this before.
So... RB26/30 the 30 stroked to 3.4L, The head fully built to suit the GTRS's, that goes through the 6sp Getrag and that goes through the BNR34 V-spec subframe.
Something over 400kw
