if you get stuck, ask Jack88, he's installed one into his car before
-D
done about 11 of them lol.
you can use a 150 - 300 watt inverter but there fairly power hungry or you can use a DC - DC power supply which replaces the 240v unit in the xbox, need to rewire the loom in the xbox for it though. PM me if you need to know anymore.
Jack
Yeah keen for it bud. I'll get back to you for sure on that.
Currently licking my wounds from the track day at Lala. 3rd session I collided with another bike at turn 5 and we both ended up in the dirt. Bike has a fair bit of cosmetic damage. Crushed my hand and broken a finger. Bruising is looking pretty awesome now :)
Time for painkillers and beer!
Getting some respray work done on the bumpers on the car this weekend. should look decent when its done
-D
Looks good, where you getting it done?
i got monkey bars yo'
You still need to send me pics of those rims.
Would look better with a front lip :)
Truth!
However. My R32 has stock suspension yet I still manage to scrape the lip in some places, isnt that the reason why he removed it?
Cheers...Can i play on your monkey bars? :D
That sounds weird. :bunny:
front lip = wank
the car is setup for handling on the road, and despite it not being as low as a track car, the lip does not cut daily driving - always scraping shit, steep driveways etc. as it is with the lip removed, i still have my zorst scraping stuff - that i dont like...
i would chuck it on if it would line up with the rest of the bodyline, but i do like the look sans lip - less 'kick me in the balls' for the po po
i can understand the lip for those who track/weekend warriors/wannabes who need that 0.01% of downforce but each to his own :bunny:
-D
Road & Track Dyno, - theyre my boys
Dont trust anyone but these guys to service my R
The guy who is doing my cosmetics has been pulled out of retirement as a favour to the owner of Road & track, mainly because I'm doing a complete overhaul of their IT, but also because I've needed these blokes to do a stupendous amount of work for me lately..
Spent a few hours there today while copying over their databases, met Charlie Kovaks and saw the 6lt V8 gen3 that Gil Cameron is building for his racing ute... veeeeeeeery sexy
-D
front lip = wank
i can understand the lip for those who track/weekend warriors/wannabes who need that 0.01% of downforce but each to his own :)
-D
dont you also loose your brake ducts??? =\
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
