hey i want to remove my stock bov and was wondering which pipes i should block, could i remove them all together.
in the picture could i remove that section of metal pipe and do i block off the left over pipes? the metal pipe comes out of the afm rubber intake pipe, would i just block the hole in the rubber pipe? really i want an answer of what i can and cant block.
Edited by silvercam
https://www.sau.com.au/forums/topic/188605-could-i-remove-my-stock-bov/
alright what about the right angle pipe that joins onto my rocker cover feed where my catch can is hooked onto. could i block if off or rig it up to go back to my catch can as well
anyone someone must be running with out one?
ok look at the pic and see if it makes sense
1. take the bov off block it up
2 block off the hose at both ends
3 you can either block them off or use what the r33 use which is a hose that joins 3 to 4 to 3 again
4 is the hose that runs form each cam cover also block off the other number 4
5 block that off as well
in all honesty i would not block off the cam cover ones and the one into the plenum
some fella didnt design it just cause he thought it would look good it serves it purpose and look neat
i think he wants the dose??
hey mate thanks heaps i want to remove some pipeing and want to fit a strut brace soon but it will be in he way i am going to run with out one as i cant be bothered fitting one into my piping atm
don't block anything to do with the oil breather. if you do you will end up with oil sprayed all over you engine bay.
if you want to block of the bov and not run one just make up a plate to go in between the standard bov and where it bolts to. that way you don't get any vac leaks. or if you want to take it out, block off with a plate where it bolts to, block the 25mm vac hose that comes out of the bov and block the vacuum line that actuates the bov. there is no need to remove the black steel pipe.
guys, get a life.
its his car, he'll do whatever the f**k he wants to it.
if you want to block the bov off, take your BOV off and trace the shape of its flange and bolt holes onto a rolled out coke can. cut it out and shove it between the flange and the crossover pipe (where it sits) and tighten.
strut brace wont hit your bov. you should have plenty of room to fit one without removing anything.
i kinda want that black steel pipe out of the way so i have more room and that. Is it possible or no one ever removes it? i have heard all the storys and that about not running one mate brother hasnt run one for 2 years or so no dramas
Edited by silvercam
i have an s13 with an rb20 in it every pic i seen with a strut brace has the bov blocked off becuase it is in line with the strut towers not unless u have an 13 with an rb20 running a stock bov and u have a strut braces ?
guys, get a life.
wow didnt think it was that bad just wanted to know how to remove the pipeing and that dont know if i will do it yet or not so dont stress yet lol
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
