http://www.news.com.au/story/0,23599,22561426-1702,00.html
Panel beaters/car detailers in Artarmon...went down there this morning to drop old mans car off at mechanics and whole rosds blocked off, scene didnt look to good and there was roumers around that a body was in there.
Ouch, not good.
https://www.sau.com.au/forums/topic/188686-hope-no-ones-car-was-here/
that's what I was thinking, but they don't really have a detailers down stairs and a body shop upstairs. it could be hillermans? I think they are set out like that, kind of.
no it wasn't hillarmans, it was on the corner of claredon and hottham, i don't know the name of the shop, but the detailing business below it was laser detailing. I work down the road (50m) and couldn't park at work since the police had blocked of the surrounding streets. The area around it is still blocked of and forensics are still there and its has been declared a crime scence as far as i know, as a CCTV camera from somewhere across the road apparently got footage of 2 men running out of the builing, one supposedly with a piece of clothing on fire. Either way, theres still alot of police and fire investigators there (insurance job maybe) and there's still bricks etc, on the road from where the wall has collapsed.
Thank for giving me somewhere to park yesterday aswell chubbs :w00t:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
