to the stroker that just pulled up right out the front of the motorbike panelshop in tullamarine in an R32 GTS with personlised plate and done a big wheelie
Your a dick and if you do it again i will throw the heaviest chunk of steel i have here right at your windscreen...i just had the cops come past and pester us about it
have a nice day
https://www.sau.com.au/forums/topic/188711-tosser/
Maybe we need a generic tosser post that can be a sticky.
Would also like to add that the Grade A Cock who rode into my bike on Monday and caused a fair bit of damage will be sought by me. I have his number but he won't answer it. I also have the lens from his prescription glasses which will have a hole drilled in it if he doesnt reply soon. Police after first telling me they will take care of it have now done a u bolt and told me to contact a solictor. Will call up and speak to the original policeman who actually sounded like he knew what he was talking about rather than "ya might want to call a solicitor mate" from the the other one and who wouldnt talk to me about it as the other one had spoken to me first!! GRRR!!!
End of rant about tosser (idiot on a bike not the police BTW before anyone complains).
https://www.sau.com.au/forums/topic/188711-tosser/#findComment-3403197
hehe alan u nutcase
send him pieces of the lens in the mail as a warning
I would rather put them in his tyres :thumbsup:
He objected to me picking myself up off the floor and calling him a fu**en moron as he was about 40 and felt he has a superior status over me. So to add effect, I called him it again!
Bloke is a punk and if I have to wait there for him, I will.
He ran a cycle give way point and told me "accidents happen" as he picked himself up the floor and was about to cycle away until I prepared to chase after him!
These are custom built radial spoked rims with XT hubs.
Pic of scumbag's damage:
https://www.sau.com.au/forums/topic/188711-tosser/#findComment-3403421
Try and modify his lens in some way, maybe put some magnifying glass on it or something. Try and make it so when he puts the lens back in his glasses the sun will then focus directly onto his retna, it will probably burn his retna and make him go blind. You know how you can burn stuff when u get the sun going into the magnifying glass on the right angle.. well like that.
https://www.sau.com.au/forums/topic/188711-tosser/#findComment-3403427
Bad luck on bike damage there Alan. I feel your pain.
I was on my to work one day and was taken out by a kid on his way to school, of all things, the accident knocked me unconcious and did over $2k damage to my bike. The kid had a scrape on his elbow. his mother shit herself when she heard how much it was going to cost to repair my bike so got legal advice and apparently she was NOT legally responsible for his action (f$#ked if I know how that works) but basically all I could do at the time was to sue the kid and have him pay me damages out of his pocket money (if he has any) for years at 50cents a week! Because it happened on a bike track TAC doesn't care about it! First Rant...
Last night (on my way home from the National launch of the new M3 ah hum! :D) this F$#kwit in a Falcon speeds up to block me from merging from the left lane when I was 3 or 4 car lengths in front of him. Nearly forced me off the road then when I pulled in behind him and sounded my horn he jumped on the breaks so hard I had to avoid hitting him! I was friggin furious. When I drove past him he blows me a kiss.... arghhhhh I was too mad to even think of getting his licence plate! What the hell is wrong with some people!? :w00t: Jealousy?
https://www.sau.com.au/forums/topic/188711-tosser/#findComment-3404220
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
