Just bought a coilover kit for the R32 Whiteline/SK Bilstein R32 GT-R suspension.
Matt (as in son of SK who is looking after stuff whilst Gary is in the US) said I needed to machine another groove into the shock. Unfortunately he couldn't help with where.
Has anyone with the kit got the location(s) of thee extra grooves?
  • Replies 41
Posted Images
Well the ones I got came pre-grooved, they were every 9mm from memory, right up and down the shock body from the original point. And they are quite shallow grooves only a mil or 2. Since they are not adustable (well thread adjustable like many jap ones) you need the circlip groove in the right place.
I've got this kit for my R32 GTS-t, I got the extra groove machined about 50mm lower. My spring seats sit a bit lower than halfway (so plenty of adjustment to go on both sides) with 7/5 kg/mm 200mm springs. Rears also have helpers.
My ride height is 350mm front and 340mm rear.
????? Got mine from Gary with the thread adjusters??
helper springs on the rear do a great job of keeping the springs trapped at full droop
The fronts however dont have helpers and when jacked up ie full droop springs are not trapped?
Should I be changing or machining another slot to prevent this??
Any chance of a photo? Springs should be trapped at full droop...
Anyway, here is a photo of the shocks as they are presently. When the Eibach springs arrive they need an extra groove machined into them. But where?
Edited by djr81
I would expect the location of the extra groove to depend on the spring rate and overall dimension of the Eibach compared with other (Kings) spring.
I would expect Whiteline themselves could set up the new groove for you (or at least point you at someone who could).
Well problem being that I don't live anywhere near Whiteline, or for that matter anyone else who knows much about Skylines - the joys of living in regional WA I suppose.
Pics are a bit iffy (camera phone) but hopefully help,
guess who is pulling them out to reattach the dust covers and readjust heights again?
these are set at 350 but will bring them back up to 355 this should just about keep the springs trapped I hope
Last pic you can see how much they are not trapped looks more than 5mm
well I can see 6 extra grooves, you just need more? continue exactly the same up or down the shock body to where you think they should be, or make a groove in exactly the right place if you know where it should be.
I would say stick the circlip in the bottom groove, put the shocks together and see how it is. If you can get your desired height from that, then you're fine.
How low the sleave needs to go depends on your spring rates and dimensions.
our Targa car has bilstein suspention like noone's.
I was having a look at our spare set yesterday, and the threaded adjuster is just a tube that slides over the shock, and if you take the tube off the 6 circlip adjusters are under it, it appears that there has been an extra circlip put in below all the others to hold the tube.
I'm interested to know if they are the same shock as the sk kit. I'll get pn's during the week (and pics if there wanted)
Edited by sav man
mine are from the group buy and even at 355 dont seem to totally trap the springs in the front
Will have to take em back out to reattach the dustcovers, have been a little busy :)
will have a look to see if I have the extra circlips might need to try another height for the threaded sleeve bit
they are most likely teh same bilsteins, but have had bilstein sleeves put in them(thats what the tube is), wich gives you a threaded body now for adjusting height!
I am interested in these sleeves as i would like to try them.
They're the same shocks as the groupbuy, but have been revalved to suit the higher rates (well that's what mine are anyway)
I've had no problems with springs being untrapped at full droop on the front though? Running 350mm ride height, the springs have about 20mm preload on them...
I do need longer helpers on the rear though, running 340mm ride height, the springs are untrapped by about 10mm, this is with 60mm helpers.
7/5 kg/mm springs too.
Edited by salad
cool, i need to get some group buy bilstein's with coil over kit for my car. As the Targa car has a better quality ride on the road than my car with it's dodgy old tenebe's (that even before you get to the track)
My stuff arrived yesterday. Looks very bling. The threaded sleeve looks long enough to make installing the groove relatively easy. Doesn't much matter if it is +/-10mm in either direction.
Couple points/questions from the first set of photos:
1. Where is your lock ring?
2. If your spring isn't trapped you probably need a helper.
Oh and does anyone know where to get the spanners from?
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
