  • Replies 63
I question it for only 2 reasons
1. if it was rwkw then i can understand, 300awkw is a solid 330+rwkw
2. 300awkw on 15psi with low mounts is very hard to believe
but hey good luck to you, take it down the quarter and then we will see for sure
i dont see why its so funny?
15psi on a gt40 is different to 15psi on standard compressor wheel
if he has upgraded twins then why is it so funny (or insanely impossible) that he is making 300awkw at that pressure?
all the pressure does is dictate compressor wheel speed which dials in the desired airflow based on the compressor map
true, but if they're std turbos, there's no way at 15psi it will make 300awkw.
if they're larger (say 2530s) on std capacity, even at 15psi it will not make 300awkw - plus you should be able to tell that it's non standard.
so what I'm saying is i reckon it's a happy dyno :)
yeah standard turbos will not make 300kw at 15psi, i dont think anyone has said that here.
2530s at 15psi will make well over 300kw i would expect, gt-ss make just on 300kw
maybe the dyno was done in 3rd gear, maybe its got tons of correction, maybe its a legit figure
yeah but you'd be aware of the increased lag if you had 2530s... and ALOT more power than standard.
no u wouldnt... if it was the only GTR u had been in or owned and it was done before u bought it then why would u be aware of it?
well i havent been in another GTR but bry has.. he said back then that mine was much much quicker than his mates GTR which was "stock"... now i dont know about u guys.. but it is laggy.. this isnt the first turbo car ive had.. infact.. this is among the slowest turbo cars ive owned..
This is a laggy GTR.. most ppl say that the stockers will be on full song by 3500... well by 3500 ive only got 8psi... it doesnt hit full boost till 4.5k.. u can see that on the results as well.. just over 4.5k and its hit its 15psi.
This isnt a stock car.. thats what ive been tryin to say all along.. it was MEANT to be stock, but it clearly isnt and as far as i can tell.. the only mods visible r, computer + boost + exhaust.. now mods that r for sure done.. turbos atleast.
If it was a happy dyno.. then my mates evo 8 mr which is runnin 23psi and a full turbo back exhaust doesnt make 210kw either.... if i do indeed have stock turbos then the dyno is out by atleast 50-60kw so id be seeing a more realistic figure of 220-230kw... which means my mates evo 8 makes what... 140-150kw?? i think not. a stock evo makes closer to 180 and a modified one with boost makes over 200 easy as piss
dyno might be out 10-15kw.. might.. but that still leaves me with modified turbos
stock is 19 peak and falls off to 16 from memory...so 23 doesnt seem over the top.
yeah evo's love the boost. a TME we slapped togethher that will be featured in Zoom soon and the fckr makes a solid 317awkw at 1.3bar on a std bottom end with a smal td06l2-20g... try that on a sr or rb and you will be picking up pieces :P
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
