WazR32GTSt Posted October 15, 2007 Share Posted October 15, 2007 (edited) EDIT: ok this thread has had a total re-do now that i have actually done this so i read on the G35driver forums how much better it would be to have the tiptronic around hteother way, and i've got to say now that i totally agree! i have just switched it around and its infinately better! that is.. PULL BACK = next gear PUSH FORWARD = previous gear here's a DIY way to change the direction ofthe tiptronic in 15mins of less, for only $5, and that is totally reversible! the original thread that i thank for giving me the knowledge of which wires to find: http://g35driver.com/forums/showthread.php?t=122292 tools needed: - side cutters - plyers - 2*blade connectors - female - 2*blade connectors - male - electrical tape time needed: 15mins picture 1: pull the centre part of your dash off using info on these forums you will see a few wires which run around behind the gear selector and these are involved in the tiptronic switching locate the 2 wires which send the signal back to the ECU when the gear has been manually chagned the colours you are looking for are DARK GREEN and LIGHT GREY picture 2: another close-up of the wires in question. note that there is also a light green wire so don't get confused picture 3: cut these 2 wires and strip all 4 free ends picture 4: attach the male and female ends of the blade connectors using the pliers to hold the wires in place. you could probablhy solder them if you could be bothered picture 5: connect the wires the key here is that you want to swap the wires around so that the grey is now connecting with the green for both wires note that as you have used blade connectors, it is very easy to simply pull out the connector and put the configuration back to normal if you ever want to! picture 6: usign electrical tape, cover the exposed metal of the connectors and put the wires back into their normal position. you can hardly notice that anything is done! put your trim back in place test drive: amazing, simply amazing. its stuipd that it wasn't this way to start with. summary: this is a DIY that costs the price of a box of connectors and takes about 15mins to do. not only that, but it is completely reversible in the event that you change your mind! i'm going to get some custom stickers made up that have a " + " and " - " sign on them for completeness. they will be black like the P-R-N-D indicator on the other side of the shifter enjoy! cheers, Warren Edited April 16, 2008 by WazR32GTSt Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/ Share on other sites More sharing options...
WazR32GTSt Posted October 15, 2007 Author Share Posted October 15, 2007 here's a few pics of someone pulling hte centre console apart too.. seems that its very easy with no screws, just clips! http://g35ipod.com/installHW.php?skin=1&src=forum Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-3412455 Share on other sites More sharing options...
cookie--monster Posted October 15, 2007 Share Posted October 15, 2007 here's a few pics of someone pulling hte centre console apart too.. seems that its very easy with no screws, just clips!http://g35ipod.com/installHW.php?skin=1&src=forum just be very carefull with the clips.if you break them your dash will rattle and squeek forever.Anyone who has owned an r32 will know what im talking about....just take your time! Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-3413644 Share on other sites More sharing options...
ssshonky Posted October 15, 2007 Share Posted October 15, 2007 good writeup there and very simple hey? the only problem is if another driver ever gets into your car and looks at the + and - indicators they might do some damage. I guess you can just tell em hey? Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-3413655 Share on other sites More sharing options...
WazR32GTSt Posted October 16, 2007 Author Share Posted October 16, 2007 well my thinking was: do it, see if you like it, if you do then get new stickers made up with " + " and " - " on them to put over the originals Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-3414326 Share on other sites More sharing options...
WazR32GTSt Posted April 16, 2008 Author Share Posted April 16, 2008 ok i have just re-done this thread and edited the first post this is an amazing mod i recommend EVERYONE with a 5sp auto to go and do it right now! Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-3799913 Share on other sites More sharing options...
Jetwreck Posted October 25, 2008 Share Posted October 25, 2008 ok i have just re-done this thread and edited the first post this is an amazing mod i recommend EVERYONE with a 5sp auto to go and do it right now! don't know why NISSAN did it the other way around......change done straight away....top stuff Warren. Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-4217975 Share on other sites More sharing options...
Stephen Thorpe Posted October 25, 2008 Share Posted October 25, 2008 Seems much more logical this way. Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-4218125 Share on other sites More sharing options...
andy65b Posted October 25, 2008 Share Posted October 25, 2008 Great work Waz. Feels much nicer now. Perfect for the M35. Cheers Andy PS. Waz you should be getting the M35 now you need family transport... Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-4218185 Share on other sites More sharing options...
WazR32GTSt Posted October 26, 2008 Author Share Posted October 26, 2008 can't do anything until the V35 sells! Link to comment https://www.sau.com.au/forums/topic/189357-tiptronic-diy-change-of-direction/#findComment-4218648 Share on other sites More sharing options...
