Thought I'd stick the build pocess of the second evolution of my 260RS.
My car came off the road in February after an incident involving 2 blocked injectors, an incorrectly added 8 degrees of timing advancement, 30PSI boost spike and 8,500RPM.
So I left it off the road to do the car once and for all (audio, aesthetics, power).
Engine:
RB26DETT
N1 Block
Tomei Modified Tomei Forged Pistons
Tomei Forged Conrods
Tomei Forged Full Counterweight Crank
Tomei Cam Shafts (IN 260 / 10.85 EX 270 10.85)
Tomei Slide Cam Pulleys
Tomei Valve Springs Type B
Tomei Valve Spring Retainers
Tomei Valve Lifters
Tomei Valve Guides
Custom Ported, Polished and machined Head
ARP Conrod Bolts
Nismo Plenum
Nismo Oil Pump
Nismo Oil Baffles
HKS T04Z Turbo
HKS Extractor Manifold
HKS Front Pipe
HKS Drag 60mm External Wastegate
HKS Dump Pipe
A’PEXi 4” Exhaust
Nismo Metal Head Gasket
Tomei Metal Throttle Gaskets
Tomei Metal Intake Gaskets
HKS Metal Exhaust Gasket
Tomei Fuel Pumps (x2)
Sard 800cc Injectors
Sard Fuel Pressure Regulator
Tomei Fuel Rail
Dual Fuel Coolers
Audio:
Hybrid Audio Legatia 6.5" (x4)
Hybrid Audio Legatia 3" (x4)
Hybrid Audio Legatia 1" (x2)
Carrozzeria / Pioneer DEX-P01ii
Carrozzeria / Pioneer DEQ-P01ii
Kicker SX900.4
Kicker SX1250.1
Kicker KX200.2
Kicker SXRC
Repainted engine bay:
Donor Door skins so I didn't anihilate my originals:
Procoated manifold and front pipe:
New front seats to match the rest of the interior:
The boot (About 50% complete):
Front passenger 6.5" 's are in (still have to make panels):
Drivers speakers in now:
First shipment arrived... >_<
Head Bolts, valve springs, valve guides, valve buckets, valve retainers, EVC, clutch plates, cam shafts, pistons (now Tomei), gasket and rebuild kit, N1 block
N1 Block:
[/size]
Edited by pure_methamphetamachine
https://www.sau.com.au/forums/topic/189603-p-spec-ii-260rs/
  • Replies 82
Sound control central and new instrument panel in:
The front of the car is partly back together!!!
The boot is SO close, yet so far away...
I have this thing for stainless steel. Every bolt in the engine bay is stainless allen key head cap screw. Every nut and washer stainless. Whether is is for the engine, guards, brackets, clips, whatever, it's all stainless. The doors are held on by stainless bolts, the interior panels throughout the entire boot are stainless, so too is everything with the audio. I needed to make a battery clamping system. I had several ideas, then binned them so I could use stainless.
Yes, I need to go to Stainless Anonymous...
Battery clamp
Circuit breakers
New plenum...
The wiring nightmare....
This is the charging system and sub lines. It's kind of messy, but at least this way it is very easily tracable for all the wires (IGN, ACC, front battery, rear batteries, EQ's fibre optical lines, EQ IP BUS line, solenoid, voltmeter earths, ammeter earths, fuse breaker earths, fuel pumps relay system, system remote relay system...) The list keeps going...
At least it is all hidden...
The front is back on. All parts repainted or replaced. Stainless cap screws as per usual...:
Door panel made. It's been dropped off to get covered:
Duel fuel filter holder:
The custom battery clamps / distribution blocks:
Stereo all works. Rather loud... Needs a serious tune though. I'll do that when the car is finished
Making a cold air box (template) that seals on the bonnet itself. There is surprisingly little room in an engine bay with no engine in it. Height was the issue really...
Feet...
Like a glove:
There a couple of mm spare to allow for the sealing system:
Templates getting cut then thermal procoated.
https://www.sau.com.au/forums/topic/189603-p-spec-ii-260rs/#findComment-3416263
Pistons and rods:
New forged full counterweight crank:
HID installed:
Drivers:
Passenger:
Everything I need for oil, water, vacuum and pressure lines:
Twin Plate Clutch with Chromium Molybdium Flywheel:
Boot complete:
Door panels done. They look like arse, so I am going to remake at Christmas...:
Passenger:
Drivers:
The intercooler is kind of deep (115mm):
So I modified the bumper:
Figured I may as well move the oil cooler again, and will modify the bumper more by adding a side air scoop / duct for the oil cooler:
And now the bits that bolt onto the plenum are shiny too:
Cut the bumper
Got the initial glass section in:
And I have my PnP head back:
https://www.sau.com.au/forums/topic/189603-p-spec-ii-260rs/#findComment-3416271
all those photo's make me dizzy. :P
shall be one hell of a 260RS (and debt for that matter) when its done however..
that engine crane is a bloody good idea!
i assume it lets you adjust the angle of the engine? i had issues as i dropped the whole engine and box in mine, and the angle had to be steep to get the box under the tunnel, then i struggled to pull it back up and drop the engine on the mounts.
PS: what are you lurking down there for dale? still trying to clean up the mess you made? >_<
https://www.sau.com.au/forums/topic/189603-p-spec-ii-260rs/#findComment-3416299
AHH superb project Simon!! Nice to hear from you again. The photos makes me HIGH!!!! LOL!!
Very good. what is your expected final Kw at the tune? Give me your address too (kidding!!) Damn how i wish i was an engineer!!!
Ohh Ilike the "ASS lube "too. >_<
https://www.sau.com.au/forums/topic/189603-p-spec-ii-260rs/#findComment-3416486
Most of us here own a Stagea, but this is undoubtably THE Stagea to rule all!
Good work - that's gotta take a hell of a lot of dedication, money and sanity.
There was a heavily-modded 260RS for sale on J-Spec a few weeks ago, but it's got nothing on this monster!
https://www.sau.com.au/forums/topic/189603-p-spec-ii-260rs/#findComment-3417219
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
