before you pay $790 for that set get a price for Hankook Ventus K104... same price awesome tyre, far superior to Nankang without doubt cant comment with Fedral never tried them. The Ventus K104 is the shitz ..... 235/40/17 for $190 each and Im using R34GTT mags
edit: ahh 18's my bad. hhmm price the K104's anyway =D
I've got 595 0n 17's. Wear is OK. 33k at present, on the rears. Got about another 5k . Cant tell about the fronts, as a dodgy tie rod end scrubbed them
out.
I find them a bit noisy though.
K104's FTW!
I put K104's on my car and while I haven't had any traction issues I find the fronts are a bit funny with off centre feel. Maybe I was just spoiled with the Dunlop Formula W10's that were on my car when I bought it... they were clearly a few years old and but it felt like the front end was glued to the road. F*ck they were noisy though.
had federals on my stagea when i got it and they were lucky to last 30,000klms. they are crap and if you really want a decent tyre go for michelin all the way.
i switched and man what a difference in ride, so much smoother and quiet to boot!!!
just my 2 cents
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
