  • Replies 59
Howard's a lying smug fu(ktard, Rudd will be a lying smug fu(ktard.
Yeah the ecconomy might go to shit with Rudd but at what cost does it do well with Howard. Can't afford a house, inflation it at it highest ever....and tax cuts, what a fu(ken laugh, we get tax cuts, then people spend more, we are no better off. It's one big fu(ken scam.
DONKEH for the win!
https://www.sau.com.au/forums/topic/190184-howard-vs-rudd/#findComment-3425946
I think i'll vote Rudd at this stage for a few reasons;
1. Educatuion policy, I think university should be free, howard has made the system user pays and hence O/S students are buying our uni places.
2. Howard is a liar, plain and simple.
3. Howards IR laws disadvantage those who can least afford it, people who depend on penalty rates, loadings ect.
4. Rudd is addressing climate change, Howard wont even ratify Kyoto!
Thats said I am not 100% behind Rudd, I will continue to watch the campaign closely.
https://www.sau.com.au/forums/topic/190184-howard-vs-rudd/#findComment-3426096
Howard.
We can't ratify Kyoto without severely disadvantaging ourselves in the global economy against higher polluters.
Ratifying Kyoto is simply a political point, and I completely agree with Howard's attitude to this.
If you've ever been in a business where idiots who do nothing, constantly mess up and basically fleece the employer because its so difficult to sack them you will be all for IR reforms.
BASS OUT
https://www.sau.com.au/forums/topic/190184-howard-vs-rudd/#findComment-3426122
Hmm, interesting.
1. The Hawke/Keating government introduced the HECS (Higher Education Contribution Scheme) which means if you go to uni you pay the tax man. Plain & simple. O/S (full fee paying) student have been at our unis for many, many years. Good on them. Why should they be denied an education as well?
2. All politicians are liars. Plain & simple. Actually they are not. If you (or anyone else) had everything they ever said scrutinised & debated & misrepresented then you too (& me & everyone else) would be termed a liar. Rudd has the advantage of not having been around long enough to have piled up baggage.
3. Howard fkd up on the first change when they introduced the AWA's. But now that they have implemented a no disadvantage test covering the most important benifits you can't get little of no compensation for trading your penalty rates etc. Try working on a salary - you don't get any O/T, penalty rates or anything other than your salary. Not everyone works on wages or can even get access to AWA's.
4. Kyoto is a lame duck. Ratifying it will make bugger all difference. If Rudd had any bollocks he wouldn't be banging on about a target in 2050 - thats what four changes of government & 15 elections away. He would map out a short term target (say every year until 2020) & set out how he would achieve it. So would Howard. But they are both too gutless.
To finish: what I hate the most about this election is the me too, cloning that is going on in the policy areas. Weak as piss.
https://www.sau.com.au/forums/topic/190184-howard-vs-rudd/#findComment-3426134
Wait, Labor is going to make uni spots free and stop international students? Where'd they say that and as if that makes any sense.
Rudd's not a liar though, hard to lie when you never answer a question.
You CANNOT be stripped of penalty rates, loading etc without compensation.
Rudd hasn't addressed anything, he's crapped on about studies that they commisioned that won't tell him anything until it will mean very little to this election. All he has done is made promises about carbon emissions when he'll most likely be dead.
https://www.sau.com.au/forums/topic/190184-howard-vs-rudd/#findComment-3426151
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
