Track day?
Dyno days are frequent enough. There has been a few run by SVD at Tilbrooks Auto n Dyno n possibly a couple at RPM Performance Centre.. could be wrong.
As for track days I haven't heard of one yet...But i kno for $40 or somethin you can go out 2 mallala on an open day for a blast around which'd be a pretty good thrill
https://www.sau.com.au/forums/topic/19093-track-day/#findComment-411377
Guest skyhi
Hmmm, interesting... cheers for that. Yeah i wouldnt mind having a crack @ mallala, or just anywhere with a bit of run off area so you can have a decent go. So $40 aint bad... proly need a helmet & and harnesses or something i guess. Hey Timmaaay (or anyone) is there a place where u can advertise cars for sale on this or maybe SDU website?
https://www.sau.com.au/forums/topic/19093-track-day/#findComment-412616
Yeah it is fun at mallala , Munro and i went out there 1 time, He had his old holden ute at that stage with the 308-350 stroker. I remember his wheels getting so hot all his Centerline caps fell off. I ven took my GTR for a spin in its Drag configuration and managed to get 190kph down the back straight 4.56 diff gears at over 7000rpm was so much fun. Mind u i stuffed my engine and scorched all my bearings but was so worth it :] That little thing of mine hoots around there even with wrong suspension. Full drifts coming out corners etc. Only cost 50 bucks for the day back then. Recomend it to anyone. Great skill driver training as well :]
Just dont do yoo many laps in 1 hit as its realy bad on car wear and generaly got very hot eng, gearbox temps quickly.
https://www.sau.com.au/forums/topic/19093-track-day/#findComment-436226
  • 3 weeks later...
I've been testing the Gtech pro with a mate and the result is fairly accurate. The run can also be saved and downloaded onto a laptop for analysis. We should have this organise soon.
May be we should have random weight days at some weight bridge before the mallala day. We can then do a mallala day with 3/4 days of track and 1/4 day of drag strip performance :)
Does anyone have access to a weight bridge?
Does mallala provide open day on the weekend?
https://www.sau.com.au/forums/topic/19093-track-day/#findComment-488196
  • 2 years later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
