Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hillzy,
So your currently not driving your car?
If its going to blow up it will blow up on the road. If your worried about running it up on the dyno definitely do not give it a boot on the road as the road is not a controlled environment; you can't hear or see it pinging so you keep your foot in to it and BANG! :)
Oh everythings fine with it. Doesn't miss a beat! The thing is thrashing it right to the red line a few times on the dyno makes me all antsy in my pantsy.
Is it very hard on the engine?
  • Replies 326
Posted Images
You worry too much. :)
Its about as hard on the engine as overtaking on the open road in third gear.
If this is your first dyno day come along for a look see; you'll see no cars blow up etc and how its nothing more than a 5second run to peak power and then off again. :D
haha
thrashing to the red line gets you worried? geeze, my RB25 spends 99% of its time on the limiter :dry: Ive thrashed my RB's more then most people on here will ever do... and not had one blow, let alone a power run on the dyno :P
as joel said, its a good opportunity to run it up anc check your AFR's and make sure all is A OK as you never know when your fuel pump might decide to cark it
Yes It will be at Boostworx again. Boostworx have the best price for a dyno day.
Myself I'm not too keen on spending $50 for a power run that some of the other dyno operators are charging when all you receive is a laminated dyno sheet with possibly a picture. GW does both 2wd and 4wd $40 and $50 respectively but $10 is $10.
I feel $30 is quite reasonable. A BBQ and Cold drinks will be available; Boostworx also has evap aircon so there will be plenty of air movement.
If the weather is possibly hot/warm it could be a really good time to hold a dyno day depending on how you look at it.
Its always good to have the car on the dyno during hot weather as you are able to find out how it runs in such conditions.
Is it pinging. Is it safe to give it a bit of a boot during hot weather?
So for those of you that don't have the car run up both in cold and hot weather it will be a good chance to see if the car is running well.
However... If the majority would like the day to be held a little later by all means it can be done. :rofl:
I personally don't mind the idea of a warm dyno day as its a good check up.
I'm glad that it is at Boostworx as all my previous dyno tuning was done there so I can compare results from the same dyno. Your point about having a dyno run in hot weather is valid as well.
Count me in.
Hey Shaun, hows things?
Car sounds just a little different now......
Hey Andrew,
All is going well just not as well as yours. lol
Have youy sold your black GTST yet or not? Might have someone that is interested if it is still about!!!
  • 1 month later...
Hey ppls,
Unsure how this thread ended up closed; maybe I clicked something without realizing. :woot:
This dyno day is still up and running.
I'll look at getting peoples to start laying some $$ down to secure the day.
If we don't get the required minimum the day won't go ahead. Which is unlikely given the interest shown.
We need a minimum of 10 people to pay in full ($30), those that pay first get to choose when they want to run. Those that don't pay upfront don't get to choose and their spot may not be secured if there are too many cars on the day.
Its cooler in the morning. :(
Cubes,
What's the chance of Shaun spending a little time checking/adjusting on the cars? I was thinking of putting on the turbotech before this day and doing my best to set it to about 10psi and having it checked out on the day. Do you think shaun would spend some time adjusting it if its not dead on 10psi, or is it simply on-off the rollers?
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
