SSV in Oakleigh....all the way... got my skyline there even though its non turbo... its the cleanest R33 iv ever seen and a year later no problems whats so ever...
Id chek out some private cars for sale on carsales.com or the for sale section on this forum...
thers a nice Series 2 turbo Black for sale at carsales for like 14k and thats with minor mods like front mount, turbo timer and pod... with a bit of haggling you could drop the price to 13k...
i was interested in buying that car but iv decided to turbo my current engine....
https://www.sau.com.au/forums/topic/192004-r33-gts-t/#findComment-3466404
I hope you have done a search and know what you're getting yourself into :(
Personally i would suggest you sell the NA GTS and buy a factory turboed GTST. Too many differences between to two models; slapping a turbo on the side will not give you the same power and handling :P
https://www.sau.com.au/forums/topic/192004-r33-gts-t/#findComment-3466606
yeh i have done a fair bit of searching and have a seperate thread for this exact topic on the Naturally Aspirated performance section.
Selling and buying a turbo one will cost me way too much and i know exactly what im getting into.
Chek out the thread for more info anyway... laters
https://www.sau.com.au/forums/topic/192004-r33-gts-t/#findComment-3466915
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
