It's incorrect to say that a bonnet is illegal simply because it is made from carbon fibre. If this was true how could all the R34 GTR V-Spec II's with carbon bonnets from the factory be roaming the streets. Is a carbon bonnet illegal because it shatters? What about a carbon roof like in the new M3? Wouldn't that also pose some crazy risk in a rollover...
Please link to the relevant legislation saying that bonnets made from carbon fibre are illegal.
The reason why GTR V spec and M3 have approved CF products because they go heaps of safety and crash test. They show the results on the paper and video to prove its safe for that car only for street use.
Yes this is obvious but thanks for posting it.
All I'm saying is to say a carbon fibre bonnet is illegal is not correct. To suggest a carbon fibre bonnet cannot be as strong or crash as safely is another falsity as Nissan would not be able to sell them otherwise.
To settle this properly...Contact the RTA - under the freedom of information act you get get them
to e-mail the official regulations to you.
I know because I did it with wheel and tyre regulations and they e-mailed me a 70 page pdf file
with every rule and regulation on wheels and tyres in NSW / ACT.
This must be a grey area- far as i know carbon fibre is stronger than steel. So there must be some way around regulations. Yeh i'd day some bonnets are ADR approved, from an assumption anyway.
Best to find out cause it's an EASY way to get defected.
i remember one of the concerns Holden had when they were going to put the HRT427 into production was that they might not be able to get the 100% CF bonnet to crumple in a head on collision like a steel or alu one would, and thereby posing a threat to occupants when the bonnet comes through the windscreen. the problem isn't strength, but a lack of deformability (i.e too much stiffness)
like others have said- CF bonnets aren't illegal per se, but where can you buy an aftermarket one that has satisfied the ADR's with regards to crash regulations for your particular car?
Bodywork and interior
There are general requirements concerning alterations to the bodywork:
No alteration may cause a hazard to persons due to exposed sharp edges or projections; and
No alteration may cause a reduction in the level of safety or overall strength of the vehicle.
and-
Front structure
Where ADR 10B, 10/00 or 10/01 applies, the front of the vehicle is sometimes designed to crush on impact to
absorb crash forces. Any structural modifications in this area should only be made on the advice of an engineering
signatory experienced in body and chassis structures
RTA NSW- PDF of light vehicle modification guidelines
Basically, if you can get the engineer to sign off on it, then it's legal, if they won't, it ain't legal.
They are not illegal, if you goto Custom Carbon in Brisbane they can make you a carbon fiber bonnet from scratch that is compliant, has the relative strengths and safety features to comply with ADR and still looks the goods. The law has to do with the underside structure and bracing and the way the vents are facing (if they are facing the windscreen they say oil may spray through it onto the screen obstructing your view) The guys there have done plenty of bonnets which you see on cars every day, such as the HLUCN8 GTR. Give them a call if you want info on them.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
