If anyone sees a white R33 GTST with Peninsula Mechanical on the rear window and there is a little old lady driving it...please let me know.
Just have to check up that my mum is not driving my car while I am in New York!!!!
:cheers: ill look after it
ohr32 gtr up mount tamborine
wine red 33 s1 with gold badges in ashmore, giving my car wierd looks???
But hey, ya get that dont ya :( I copped some bueaties yesterday! They were more like look stairs.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
