went for a walk through town last night so many skylines around, saw black r33 gtr plates were zilla or some variation, saw black 32 gtr, black 32 gts-t, white 33gts-t. cant remember the plates though.
I was in Bris last night at about 6.30 for work might have been me??? Who knows there are a fair few 32 gts-t's????
saw 60her ?? 4 door R32 GTS ... on ipswich road near stones corner
the chic who owns this car is pretty cool... i forget her name though. She said the car has had quite a bit of work done..i know its a manual, with intercooler and aftermarket turbo and a few other things i can't remember
Spotted a few times a chick driving nice chameleon orange R32 4 door lowered with some dished 17's or 18's getting around the Ipswich/Redbank area.
I saw that last week... chic looks quite cute..
BLK33 at autobarn slacks creek , another black comming out from shell servo logan road mt gravatt, R32 4 door with toyo stickers on the rear quarter panel at tyre power slacks creek .. white R33 series 2 at sunnybank undercover carpark black plates.. CRG33?
I saw that 33 4 door with the drift wing and chrome wheels on it driven by the guy with dreddies on evans rd, rocklea
I saw rhinorebel along waterworks road
I saw OVR440 parked IN A BUS ZONE in the city, naughty lad in his army greens and all
I saw a silver 4 door 32 on the corner of logan rd and nursery rd... even took a photo of it
I saw a silver 33 with NT plates on it (6** **6) uhm somewhere?
And countless others I forget. Easy 10 skylines a day while I'm out and about, dang things are everywhere
Hey Andrew, sorry I missed you. (you in the commodore??) Just finished footy and at 40, the trip home is a blur.....
Dave :crazy:
Nah bloke, was in the work van actually :P
Couldnt get into a position to give you the finger, err I mean wave, and besides you wouldnt recognise me hanging out of some random van :P
I think he would Andrew ;) He would go "oh, there is Andrew hanging out his random van again..."
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
