Yeh, that was me :P...i was looking at your sig yesterday and thinking the blue 32 look veeeery familiar. Very nice car btw :D
Thanks, It is a big upgrade over the R33! Your new beast is looking good too!
Saw SLO34 today on Nambour-Bli Bli Road at sunny coast today, dont lie mate your car aint SLOW!!! I also saw a dark grey/black 4 door R33 at mooloobah, I waved to you I was in the blue 4 door R33.
Chris
Saw spooks on Ipswich Road about 8:30ish this morning. We were in andrew's work van and waved and beeped but I dont think he saw us.
heard the beeps didnt know where it was coming from though!
Edited by Spook's_Skyline
i spot a white r33 sII almost every morning on my way to work on logan road near THE GLEN hotell around that area...he has a schmick looking 33 with strandard kit and front lip addon. looks hot. if anyone knows him lemme know.
i drive silver r33 sII standard kit.
thanks.
- Ross.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
