spotted this morning on anzac avenue mango hill. a silver r33 coupe... white r32 coupe... black r32 coupe and a red r33 which came off motorway, which i chased...
all nice cars
Spotted white R34 GTT next to me on Elizabeth St @ about 4:30 and a white 33 up ahead of us.
That might have been me! Pulled out of the Kings carpark around tht time..sorry didn't see you was busy concentrating on the damn traffic...saw a few 33s though...
Nah, wasn't you. it was a coupe.
we both gave it a bit off the line, he saw me gave me wave
met Nexus9 on the Gold Coast today, top bloke.
first time I have seen a V35c in the flesh, didn't like them in the pics on the net, but in the flesh .... WOW! kinda like a 350z but better.
made my 32 look cheap and nasty :D
I need a good job, so I can get one of them!
Spotted Ryan (RYN26) approx 15 minutes ago turning onto High Street, Toowong.
i waved, he waved back with a look on his face like "um... who are you?" :D
You must be "SIR32", right? Nice number plate. :D I remember you, actually we have met twice. you always wave to me, so nice :mellow: I have been trying to wave to other skyliners since I got my 32, but less and less ppl wave back now, they normaly stare at me instead.... :)
Edited by RYN26
"Driving without due care" I was the only one there driving with due care, f**king lancers doing donuts in reverse, 23 year olds who look like they have down syndrome with n/a r31 skylines putting out a supposed 300kw atw doing burnouts up and down the street and i pull out to go home and BANG, notice to appear in court.. haha <end rant> I also met Col, so that made my night :D
I also met Col, so that made my night :laugh:
Nice to meet you too... Bad about the cops tho, its always the guy doing the right thing who gets into trouble...
also spotted col... not drunk though.. very shocked
Yeah, was not sober for long tho...
Did you see the guy with the pocket bike blow the rear tyre... Classic, was very funny... :wub:
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
