Spotted
White R32 GTR "WAR32" at Aspley today about 12pm...
also
A 'bunta' blue R33 GTS-T with GTR badge at Aspley same time same place...
plus a Silver R33S2 GTS-T number plates "1olou"
Was a skyline friendly day at work today...
Spotted
He's a gtst! He's a bit dirty in this pic cos we were on the skidpan at QR.
Yesterday i got BOV'd by a yellow R32 on Logan rd while i was driving the boss's RX8!
it was weird for me.. :)
Edited by RB_turbo_bitch
i saw a white serise 2 33 plates 55UPP
7:30am end of creek road?
And some one in a silver 33 almost ran me over (okay it wasn't that close) didn't get a number plate.
8:ooam on creek road near mount gravatt tafe, next to the hobby 1 store.
55UPP works in the same complex thing that I do.
Spotted a gunmetal R33 sporting very heavy damage parked on the footpath at Bardon about 15 minutes ago, ambos had only just pulled up as we drove past. It looked like it was a VERY big hit, I hope everyone was ok and that there wasn't anyone on the footpath at the time :P
I saw that too......that R33 was fubar, i hope nobody was hurt
spotted Mr Revhead in a SMR33 skyline at 5pm driving past the milton brewery...
Would have been going to pick up Karen from work :unsure:
..with some fandangled lookin earpeace in his ear :rofl:
The earpiece is a permanent fixture. Never seen without it and it does interfere with dinner on occasion.
ROFL
Yeah sounds like me :( Bluetooth headset ftw
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
