Spotted Isacc (Konrad) on Saturday at around 3pm on the storey bridge, I was in my car but you had no hope of seeing me I was in a side street!
Spotted Marc and Karen (Revhead and SMR33) at about 4:30 in coorparoo on old cleveland road...good waving guys :) I think we scared the guy in the falcon in front of you lol
Heh yeah coming back from Karen's parents' place :( The car in front of us blocked Karen's view while we were stopped and she was asking "Who? Where? Behind us? *turns, looks around*"
I had to dawdle off the lights so that the car in the turning lane didn't block our view :happy:
Heh it's all good. Check the guidelines (link is at the top left of each page) for what's acceptable and what isn't. If you're unsure, feel free to ask a mod or an admin. Welcome to SAU :blink:
White R34 on the gateway today, stock as a rock, but great choice for the girl driving it.
Was that just before the Kuraby toll & all the way through to Murarrie?
You had the front mount with the standard bar and no exhaust?
Edited by so_tred
That was me, I've got an exhaust? It looks like a stock twin-tip one...but $2K out of pocket says otherwise ;)
Nice choice of car, I did a double take as I was merging on looked sideways and saw another R34..doesn't happen that much.
Was pretty random that I was heading that way, I had to go to the Queensland Fire and Emergency Services acadamy for petrochem fire-fighting on that day.
I passed a dark blue r32 on my way home from work.... the person lives out near beauy... anyone know this person?
There is also someone who owns a black r33 in beauy with a few mods...
Haha favourite memory from living out there is being told I drive "one of those new fangled cars" by the woman in the post office.
Ahhh...fair enough about the exhaust then :)
I did the double take too :)
spotted a white r33 plates MELS33, heading into newport at redcliffe,
and on possibly fleetwood street, a blue r33 with a black bonnet, black boot and black roof, covered in stickers. Nice ride, too many stickers to read lol.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
