spotted: silver r33 with chrome 18's and number plates that were like ipoh or something like that.. outside my house bloxed in by police cars along with 3 detectives looking around my street in shorncliffe at about 5 thismorning.. went for a little drive around the suburb and there were police everywhere, i was pulled over and asked for ID, apparently you and 4 of your mates were caught graffiting one of the trains parked at the station overnight.. class act mate.
spotted Col tonight at Gramme Rd, heading to Aspley...playing around with this lancer next to you....
did everything try to get your attention, i was in the lane next to the lancer.
btw, what bulbs are you using on your car?? or is it aftermarket HID?
Spotted a yellow R34 (GTR wheels, didn't get a close enough look to check if it was actually a GTR) parked in a private off-street lot on Sandgate Rd at Clayfield. Noice :P
Spotted RDY60 (Mark) filling up his skyline ON THE NEWS!! hahaha
:huh:
Arhhhhh Franky... Wow i did see a part of your car, all i noticed was a blue coloured r33 (all i could see was the side of the front headlight, was hard to se at night also) The guy in the lancer was trying to get me to race him so i didnt look sideways much as i didnt want to egg him on. At the next set of lights he put the hammer down... :laugh: Unfortunatlly his 40fwkw was not quite enough for my 1/4 pedal accleration... He was reving its ringer out and still he was beside me... I was laughing and he was less then impressed when i put the hammer down...
Im not one to race on the streets but i did kinda step on it just to sh1t on his 18 year old ego... (At no stage did i break any speed limits tho)...
And Yes i have HID's now... I wanted to do something not many have done, i have had them in for about a week now and i have had so many people ask about them, they look awsome.
Arhhhhh Franky... Wow i did see a part of your car, all i noticed was a blue coloured r33 (all i could see was the side of the front headlight, was hard to se at night also) The guy in the lancer was trying to get me to race him so i didnt look sideways much as i didnt want to egg him on. At the next set of lights he put the hammer down... :( Unfortunatlly his 40fwkw was not quite enough for my 1/4 pedal accleration... He was reving its ringer out and still he was beside me... I was laughing and he was less then impressed when i put the hammer down...
haha, i realised that thats why i did not beep....the kids in the lancer kept looking at me, thats why i slowed down....
u did not even hit boost, did u??lol.....
yeah, he could tell he was hitting rev limiter in his stock two door lancer...hahaha, taking off the line....
he must have felt special, in between a blue R33 and a bright yellow one...lol.
btw, the hid looks great.
Edited by frankxinyu
Spotted Spooks Skyline on Saturday (That is a lot of words starting with S :D ) on Fairfield Road and Sherwood road, Got a very big wave from all in the car! Good to see!
Also our guest from Sydney was right in the middle of saying that she had seen no good cars so far in her trip so you saved us :)
oh i totally forgot about this car until today.. so I came searching!
definately one of hte nicest cars I saw whilst I was up there.
:P
Also spotted a R32 and R34 4 door today down a eagle farm out the front of exedy's brisbane depot...
Woot!
finally spotted... was starting to think nobody loved me :P
Mine was the 34 and the 32 belongs to a work colleague... would you believe he is swapping the 32 for a celsior instead :D
what? so you can light up your front yard of a night, cus until you get your license back that car aint going anywhere :P
COl what brand did u go and What K.. i did mine a while back and im considering going brighter
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
