spotted a hot BLUE s1 r33 twice today.... gave the guy a wave he waved back....nic to see not every skyline owner out there is up themselves.....lol.
spotted the hot silver v35 across from market square at the LAN place....he's always there!
spotted a red r33 coupe with 4 stud wheels :S at Lawnton Amart today,
and then around 6ish sat behind a grey r33 plates Go Nutz, at Hungry jacks kippa -ring, sorry my mum beeped at you lol, she was looking down then next thing she saw you reversing and freaked out lol. looked a bit cramped in ya car :(
You let your mum drive your r34?? :)
You let your mum drive your r34?? :(
well no license.... and its been 13 days since it was last driven, so yeah. its once every ever 10 days ro so, once my license is back she can get fuc.ked
saw a white s1 33 with a s2 front bar in gympie at the st pats church this arvo. would've been at my mates sisters wedding. had personalised plates something along the lines of JML81. black plates with white writing. i drove past and saw it (wasn't invited to the wedding). then did a bit of a skid up the road.
Spotted White R34 Gtt with "Brisbane" design ppq plates (forgot the numbers and letters) at chermside shopping centre today parked on the roof...
Also spotted a dark blue r32 on kitchner rd stafford heights today at 2ish...
spotted ARE32 on gravatt-capalaba road inbound at about 1.30am last night
pulled up beside to see if it was who i thought it was and was also tired as shit from coast cruising all night and didn't notice a slight bend in the road
nF chased me halfway across the city, i guess he thought i was trying to ram him or something =P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
