Spotted White R32 on Bells pocket rd at strathpine this morning at about 10:30 ish...
I waved and i also recieved a wave...
I thought it was you - the bright yellow 33 was looking pretty good.
Arhhhh Harry...
I have not seen you before, i didnt know if it was a user or just a nice skyline driver...
Thanks for the wave... BTW the bottom end of that road is quite slipery in the wet...
R33S2 - did i spot you on mandew street behind the hyperdome yesterday arvo? you probably would have sen me checking out your car it looks good! I was in my old mans 4x4 as the line is getting sprayed
marc looking very smart in his shirt and tie (with earpiece in aswell) driving along ipswich road woolloongabba at 9am this morning.
i was in andy's red 33, didnt wave caus i was too busy laughing :(
Nah didnt see you, it was me though :laugh: thanks.
spotted two white R32's today..
1st one followed me off Beaudesert Rd onto mortimer rd at Acacia ridge this morning when i was off to work.
2nd one followed then overtook me on Beaudesert Rd between Calamvale and Browns plains this afternoon when i was on my way back from work..
gotta say both cars looked neat.. Skylines seem to be one of them cars that suit the colour white :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
