spotted bunta on fairfield rd this morning (was in mates corolla, saw you turning off at yeronga, was waving like a madman, mates in car wondered what the heck i was doing)
and then spotted marc in my support room getting a famous xmas pudding, so lucky!
Thank god I'm on holidays, don't have to see you stalking me everyday in the carpark :laugh:
hope this helps dan http://en.wikipedia.org/wiki/Paranoid_schizophrenia :laugh:
spotted a red 32 sedan on loganlea road around 12.30 today ( i may be stalking you too) im not :P
Edited by darren32
Hell yes, can't wait to try it, I've heard good things :)
Spotted Dave being 'impressed and thankful' later in the day
any spot me on beenleigh road pulled over by the police???
"random licence check and rbt"
bawahahahah
pull the other f**kin leg you stupid coppers.
i drive a import, of course you dipshits will use that excuse with me.
LoL you take them to court, you get the little black cross :)
nothin to do with the court.
i pulled out of my street onto beenleigh road
came up next to them at the lights (they havent even seen my plates yet)
then drove off and they were next to me startin to slow down, pulled in behind me and lights came on.
just did a licence, rego check and rbt.
dipshits didnt look like they knew wat they were doin
took 20mins!
the next check they do that takes that long, i send them a bill for 1hr of wasting my time!
going to say that choyda is stalking me
just assume i spot him once a week =P
Not a very good stalker then are they :P ?? or is it the other way around?? :(
Also saw a black 33 gts25t at mt omaney shops bout 12ish
I spotted Chris in the flesh at chermisde shopping centre yesterday...
Chris as in r33gts4door Chris, we had a nice little chat in JB Hifi... Sorry I had to cut it short buddy, my other half was just keepign track of time... We didnt finish shopping til closing time... :P
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
