Spotted a wine red R33 with SAU stickers, TLCXXX, driving along the gateway this morning.
I was in the biege beast and so you probably didn't notice me.
Spotted again, this time in the afternoon driving back along the gateway. Changed your rear wing recently?
spotted a red Cefiro plates were 352HLJ i think? with SAU sticker on back...
was behind you this morning on Gateway from about Eight Mile Plains to when you took to Port of Bris exit...
would most likely not have noticed me - was in my other car - Red Lancer :wave:
would most likely not have noticed me - was in my other car - Red Lancer :)
And its got clear lights and all Anita? If so I saw the buzz box :(
And its got clear lights and all Anita? If so I saw the buzz box :D
lol i thought it was u Dave, haven't seen u around for a while, so wasn't 100% :rofl:
haha yeah buzz box it certainly is - cheap on fuel tho - saves me $$$ in fuel compared to the Skyline for my 75km daily journey to work & back ;)
Spotted white r33 on logan rd...followed me down creek road....emm.. RYD60 i think...:)
I was in the r32 57IGG. em yes i made a fool of myself........
oh and you have the SAU sticker on the back window....cool stuff. and its good to see people smiling too, snot that often you see people who actually wave and smile back.
Nice car! I've seen it before when I havn't been in my car :)
Cheers Mate @ ready go you've a nice tidy car too....i have a kit going on mine soonish.
Spotted Lil34 on ipswitch road this arvo.. following a 200sx s15
Edited by Oblivion
Saw you JDM 34; Samantha on Parklands Drv, I followed you for a while and turned off. Sorry for not waving I am a bit vague in the mornings plus I kinda feel like I look like a tool waving..... :D
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
