spotted a horny as r32 in the garage the other day, with the donk waiting to go in...
oh wait...thats mine. how could i forget it just looks soo sexy i guess.
spotted purple 33 today on creek road..
spotted a dark grey r33 coupe with exhaust and no tinted windows leaving the myers side of the plaza at about midday. bloke in it was wearing a business shirt and tie....... never seen it or the guy before.
was really quiet considering it looked like a 3'' system
Edited by r33cruiser
Spotted Dangerous Daveo's Cefiro in my front yard yesterday.....only came over to get the Krispy Kreme's off of me :banana:
Spotted Yvonnes new shiny extreamly tidy R34, in her driveway last nite while picking up my krispy kremes (4 boxes :) )
i used to spot you on my way to work have you changed routes?
I Spotted you man ! chucking a fulli hectix left run off logan road .. i was in my audi rs4 dont drive my 34 anymore :devil: dont worry i keep a eye out on ya :P
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
