Spotted a few on the weekend.
Silver 33 heading towards nerang on sunday (on hooker blvd/Nerang Broadbeach Rd)
Saw a white 33 in Coolangatta,
Also drove down some backstreets at coolangatta/tweed (just off Kenedy Drive) and saw a house that Had 2 skylines parked beside it.
also see a maroon 33 s2 with maroon rims around tweed/coolangatta alot.
ALSO - every day, i drive past a clean white 32 in Kingscliff, thats now for sale? :thumbsup:
Edited by Sagiedaks
Spotted a few lately
yesterday afternoon i spotted a silver r34 and a maroon r33 coupes near diddilibah.
and this morning i spotted a white r33 coupe passing saint andrews drive and a speed camera.
this isnt a nissan or a skylinebut well i spotted this Confused holden barina at inala ... had M3 badges on the rear too
I hope no ones missing badges off their M3...
Also Spotted Bunta and Anna on logan road myself and Adam were trying to think whos car it was sorry we were out of our brains ...
Spotted PFC33 black S1 on logan road , Black R32 OMY32
saw a few cars out at the drags on sat anyone here go??
white 33, white 33 with a black bonnet, grey 32 and a red 33
Just to jump off topic quickly, what times were you running Mort?
Messy was trying to get me out in my line but I had other plans.
And poor Messy, snapping his rockers... ouchie lol. atleast this is an excuse for him to start the headwork on the GTiR.
red clean, wingless 34 GTT sedan in Kippa Ring this afternoon...and later on a black GTT on the hornibrook bridge with kit and wheels...
same red sedan i posted pics of on the page before this? i spotted it today aswell :D
pretty shite ones actually first run was to embarrissing to mention :D but got 14.5, 14.6 and my mate got a 14.1 in her, best shes done is 13.9
mate took his GTiR out and killed it on the first run :) so far found 2 of the little arms that go to the valves pushed off and head gasket was kool
Just wondering if the dude with the Gunmetal Grey R32 from Darling Heights, Toowoomba is a member on here.
I was following behind you on my way home at about 9:20pm tonight, I came out sideways when following you into Stenner :)
Spotted turbs33 at 7-11 tonite :) also a noob in a yellow R34 coupe without a wing white 18" wheels who tried to race me in front of cops ... mate if your on here dont even bother its good that he got caught trying to drag..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
