Spotted a metallic grey r32 Gtr parked next to a white r33 Gts-T both with Sau stickers on side skirts on both parked on front lawn in Kennedy Dr Tweed...........Oh that would me with my mates Gtr parked next to mine. lol :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
spotted LEE (phatoboi) parked on nudgee road today
and then spotted nismo (guy with the white r34 sedan, plates Blacks or something) at kippa ring shops around 4
ditto and ditto spotted both also
also spotted bryn nar newport... :D
also spotted a grey R32 with no number plates on the side of the bruce hwy at the strathpine exit looked like a little damage to the front right hand guard also...
lastlly spotted an r33 gtr at the airport (australia iar express) depot tonight at about 7:30pm
Nup...wasn't me...I was at Kippa Ring shops on Monday arvo.
Spotted gunmetal grey 33 tonight on the SE freeway heading south...had an Sau Sticker on the rear quarter window...nice ride! :D
Spotted gunmetal grey 33 tonight on the SE freeway heading south...had an Sau Sticker on the rear quarter window...nice ride! :(
oh wow, car looked identical to yours, had those black with the chrome lip rims, like i could have sworn it was urs, identical :)
althose spotted today around 2;30 on toombul road a blonde chick driving a white r32 gtr
i sware i see sunnycoast's black 34 coming up mons road this arvo round 3.45!?? was it you chris?
You wouldn't have seen me, I was in a ute! Though u would of driven right past my car parked on corner of william and burnett st.
It was me!!! I've been spotten! hehe. What were you doing up there again? See your car on william allot.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
