Just went to lunch witht he boss and saw 3 skylines.
1st: White R33 parked in the nerang Bunnings carpark, next to a silvia. Had what looked like exhaust marks on the rear bumper? I wasn't up close so couldn't really tell.
2nd: As we were going to the nerang subway (so this is like 20 seconds after i saw the ffirst, for those who know nerang) a cute blonde in an aqua-ish S2 R33 pulled up as we were. I said hey in subway :D
3rd: As we were sitting down, a white R33 GTR went past the road that goes along the highway.
Was there a meet in nerang or something? :S
Spotted 2 mroe tonight (i was on fire today or something).
White R33 GTR on the M1 at tweed, you had bright lights lol, we came along side you and gave u thumbs up, but i duno, it was cycloning outside.
Also saw a parked white R32 in coolangatta, couldnt make out any details/plates though.
okay, spotte3d a white r33 series 2, wth front bumper smashed up at aroudn 4;30 on gympie road lawnton around/
then had a greenish blue r33 series 1 following me form norhtalkes to rothwell round about around 4;45, then saw a white r33 series 2 on the rothwell round about heading into dbay,
then saw a white series one at harvey norman parking lot,.
then saw a white r33 series 2 parked on side street opposite hecrules road school.
alot of white r33 in 20 mintues lol
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
