Hi. I'm Erin. I swear there is already a thread like this somewhere.
I drive a white R33 with mags and personalised plates
I normaly smile and wave to anyone with a skyline but they normally don't wave back..
Maybe that's because I'm ugly or something :|
I've seen your line a couple of times, Erin. Recognised you from a cruise I went on (to BWCP - Easter). I usually wave at other peoples lines too but last time I saw your car I was walking through the valley and I thought you might think I was a bit weird if I waved from the footpath! :D
That's a beautiful car, Zoix.
I drive a white R33 with a carbon-fibre bonnet and I'm always out and about so if anyone sees me, say hi and :P
Sam.
nah, sorry neo, it's just been fitted and my car is still in the shop having a couple of upgrades :P cause I failed to keep left at a keep left sign :D and won't be finished till next friday. I'll take some piccies after that though. Have decided to spend a heap of cash on my car while it's out of action so can't wait till I get it back.
Time drags without your line...
hey erin i think i saw u at indro one day? and on ipswich road aspley area aswell. would that of been u? u in those areas much? whenever i see another skyline i almost always give a wave but like some of u said i just get an up turned nose and they keep driving.... i think i might just give up.....
Originally posted by Moggy
Time drags without your line... [/b]
fully dude, today was my 3 week aniversary without my baby, and it has just taken forever to go by, hopefully ill have her back tomorrow.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
