Hi. I'm Erin. I swear there is already a thread like this somewhere.
I drive a white R33 with mags and personalised plates
I normaly smile and wave to anyone with a skyline but they normally don't wave back..
Maybe that's because I'm ugly or something :|
I've seen your line a couple of times, Erin. Recognised you from a cruise I went on (to BWCP - Easter). I usually wave at other peoples lines too but last time I saw your car I was walking through the valley and I thought you might think I was a bit weird if I waved from the footpath! :D
That's a beautiful car, Zoix.
I drive a white R33 with a carbon-fibre bonnet and I'm always out and about so if anyone sees me, say hi and :P
Sam.
nah, sorry neo, it's just been fitted and my car is still in the shop having a couple of upgrades :P cause I failed to keep left at a keep left sign :D and won't be finished till next friday. I'll take some piccies after that though. Have decided to spend a heap of cash on my car while it's out of action so can't wait till I get it back.
Time drags without your line...
hey erin i think i saw u at indro one day? and on ipswich road aspley area aswell. would that of been u? u in those areas much? whenever i see another skyline i almost always give a wave but like some of u said i just get an up turned nose and they keep driving.... i think i might just give up.....
Originally posted by Moggy
Time drags without your line... [/b]
fully dude, today was my 3 week aniversary without my baby, and it has just taken forever to go by, hopefully ill have her back tomorrow.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
