Spotted a white new GTR on my way to work on the M3 today. I work out at the PA hospital so it was headed mostly that direction. Personalised plates which were black on white and the damn the car is sexy. I would post the plates up but just incase they aren't a member I wont.
alex hill last night (heading towards coles) seen a nice looking black 33.
thumbs up but wasn't looking :)
i was in the white 33 555kkr
I think i saw you.....we parked just ahead of you for a few minutes.
spotted 2 today 1st was a gun metal grey 32 gtst on boundary road off beaudesert road i pulled out of side street and ended up behind you.
2nd was along beenliegh road a silver 33gtst plates 0NY01 was cruising behind you for a while till you turned near vid ezy. was in the white 33
Spotted a white R34 ith a freaky tall rear wing... Stuck in the traffic on the riverside express way today around 1:30 - 2pm...
I was the smart arse flying up the outside of the traffic on the bike who tooted... :banana:
Maybe that was me. Say hi to everyone, My name is Alfred and I am new in here. want to meet more skyline drivers and friends. If you see an asian dude with a white R34 around that will be me!!! :bunny:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
