I saw a white 33 GTT on my way back past Redcliffe (inbound) last night on the Bruce Hwy, which looked like it had a GTR kit on it. Anyone?
Also saw a red 32 GTS/?T? with lightning graphics on the main drag @ redcliffe on Sunday around 3pm
Originally posted by Nexus9
Who was pulling out of the BP as I was driving in, on Gooding Drive on the Gold Coast on Sunday Arvo at about 1.30-2.00pm?
Was a R33 Blue-Silver colour looked pretty stock.
that would be my car, with a mate of mine driving as i have no licence.
the colour is "ice green" its a very odd colour, but its a factory colour :D
id pin my car as "slightly modded"
Yes it is an odd colour and I had not seen it before, but the colour is very nice.
Does anybody know the full range of factory colours that were released in Nippon?
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
