black 32 gtst at the spit today very clean loved the rims. parked the 33 next to you but when i came back you had left thought the cars looked pretty schmik together.
and also a 34 4 door silver 2 females pretty sure it was debadged and looked stock on ipswich road and granad road.
saw heaps of lines on sunday cruising to tamborine mtn..notable picks were black 33 loud as fook at stayplton bp... nice silver ( ithink) 33 4 door outside of tambo..and a gunmetal stagea in logan village..
34 gtr bayside blue in the city yesterday arvo bout 4
Think I saw BECKS on the M1 just near Marshall Rd exit around 4 yesterday... Was a few cars ahead so couldn't be sure.
Hmm If i seen you i would of stalked ya or at least tried to catch up lol, So i dont remember.. But i do travel home on the M1 everyday so maybe.. :D
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
