I think the guy who owns it must work at repco or cashies. I've seen it there a few times now. also spotted a p plater r31 and a very nice blue r33 on the ipswich mway goodna area both on christmas around 11ish.
damnit. I think that was me. Was the paint faded on the left side ?
spotted 60TCHA and OBA811 off hamilton rd this arvo. alos spotted a black 33 in the same area heading to nundah off hamilton and a pearl white V35 with NT plates heading the same direction.
so I have seen a few of these car today and only one I had my hands on..
Saw Big Chris this afternoon near Bunnings Carseldine in the 4 door green 33...
I should say not to big chris now...
You would not have noticed I drive a Holden these days so i didnt beep, I thought i might receive the finger... :D
Sorry to keep u in suspense lol not sure if it was faded but does yours have a sticker on it i think on the passenger window? can't really remember. and i think there was a chick in the car with you?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
