Spotted on I think Friday night.. orange R32 with Marvin The Martian plates at Alex Hills.
Also spotted a R34 4 Door boost it past me on Mt Gravatt Capalaba Road (pretty sure it was 4Door, taillights from what I could see looked like 4 door).. would have caught up but not worth it on that road during holiday season lol Then afterwards spotted another silver R34 on Dawson/Newham Rd lights, and another 4 Door R34 was going past opposite direction on Newham.. all within a couple of minutes lol
Saw a nice charcoal grey 33 this morning near the BP at Aspley. Never seen that color on a 33 before and it looked awesome. Apparently I'm not good enough to wave back at in my 32. He had his windows down, so maybe his aircon doesn't work and was jealous...
Then tonight I saw a purpleish colored 33 parked down the bottom at Aspley McDonalds. No spoiler, gay southern cross sticker on the driver's door, what appeared to be Bob Jane spec rims. Made me cringe...
Apart from those two I didn't see ANY other Skylines today. I drove from Aspley to Caloundra, around Caloundra for a while, and then home again. And they were the only two. Weird. Oh no wait... there was a Bayside Blue remote controlled R34 at one of the houses I was visiting. That was pretty cool :P
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
