46n2 - good show of restraint.
I'll comment. Drinft King Motorsport Geebung will be at Jamboree, worth dropping in to chat with them if you live north side and need riceline work done.
Saw a few nice lines out last weekend, a black R33 friday night heading into the city on gympie road, and a blue R33 heading out of the city saturday night on gympie road. Nice to see some line owners who smile and wave too :)
Saw a few nice lines out last weekend, a black R33 friday night heading into the city on gympie road, and a blue R33 heading out of the city saturday night on gympie road. Nice to see some line owners who smile and wave too :D
Hey locutus_of_bris, you wouldn't happen to know jolly Geoff would you? :)
im from the sunshine coast. i drive a white r32gtst stock as a rock (for now). right side of front bumper scratched. my own stupid fault. my garage wall got in the way. numberplate 102-ICR. usually out on the weekends at mooloolabah and maroochy. sometimes stopped at the caltex. feel free to stop say hi.
my names daniel. and i too am an alcoholic. :bahaha:
Hi Shane.
Yes, I know who you speak of, jolly Geoff is a new name for him though. He mentioned he knew you so I guess this puts it all together.
I'll be up your way saturday the 4th - then heading up to Gympie sat night for opening night of speedway then back to the gold coast sunday. Don't often cruise up there though and haven't seen many lines up there (know a few though)
Oh, also saw a few nice lines revently.
Lime green R33 heading north on gateway heading into toombul - colour certainly stands out
Dark Grey R33 - heading up gateway yesterday and ended up 1 street from where I live in Petrie. Looked very tide and original (so quiet too). I wasn't in my line so wouldn't have stood out like normal :(
Originally posted by chaos
locutus were u around milton/paddigton area yesturday arvo bout 3:30ish
Hi Chaos,
Only just saw this one, and no, can't have been me. My line is now very unique, has a nice white graze on the rear left corner. I was in the city all weekend 2 weeks ago, and saw a few lines out and about, as you would expect
Originally posted by BelGarion
i think i saw nexus9 cruising the espy a weekend or 2 ago
plates nex059
silver 33
Yep that was me :cool:
but it is gunmetal grey :rolleyes:
I want my car to be the colour of yours, love the ice green.
Or is it arctic green? Can never remember.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
