Good couple of days for the 33 four-doors......FTW
Yesterday on coro drv turning onto high st, a silver and black S2
Today a dark grey S2 on ipswich rd moorooka, and a silver and black s1 at oxley
Also a yellow 34 at moorooka as well
Ay hows it going saw you on coro drive also....noticed you waved but didnt get a chance to wave back
. Noice ride by the way, Wifey likes the color of your car.
Looks a lot better once it's been washed. :P
Yellow 34 GTR, no. plates were NITTO. Centenary Motorway on the back of a tilt tray about 5pm. No damage and a huge for sale sticker on the back, whoever brought that has my approval..... fu**ing epic.
Nitto is for sale?
I wonder what the price tag on a 1000hp gtr is..?
Think i saw Damit coming out of the BP in Manly on Sat morning, was in the Red pajero
Wouldn't of been me as car never left the garage sat and I dint wake up till sat Arvo :)
spotted a 4 door 33 today at around 4pm not sure of the colour but you passed me (black r33) on johnson road as I was turning off to forest lake. you must of given it a bit as i saw a couple of puffs of brown/black smoke.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
