I'm up here in sunny QLD for a wedding and while walking along Hooker Bvd next to Pacific Fair I turned to my GF and said, "I think I hear a lumpy R32 nearby." To which she replied, "Nope, bike."
Then we saw a gunmetal 32 with the plates RAY-xxx come down the ramp and turn left onto Hooker Bvd. Sounding ever so sweet... ...and a little smokey...
Spotted a matte black 34 gtt on an early sat morning...stephen? Looks really good.
Got snobbed by a 33 4 door tonight. I get snobbed by a fair few 33's...might stop waving at you guys as my inferior 32 should not be seen amongst fine cars. :) I joke, I still wave.
Just now spotted :
White 32, looked good until the gold wheels. Not my thing. Coming out of Railway St onto South Pine Rd.
Then, Black 34 with silver mesh sort of wheels coming INTO Railway St from Samford Rd.
Also worth mentioning I've been seeing a stock looking White 33 S2 parked in Eagers along Newmarket Rd, And a White 32 (GTR?) in a side st near Mercury also along Newmarket.
Spotted a couple r33's today, one was a black s2 turning on a roundabout just off woogaroo st at around 6.20 this morning and then a white 33 a couple minutes later turning off johnson road onto woogaroo st.
Also worth mentioning I've been seeing a stock looking White 33 S2 parked in Eagers along Newmarket Rd.
It's a salesman's car. He's not supposed to park it there, but does anyway.
Look in the street behind Eagers on any Friday and you'll find mine :D
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
