I'm up here in sunny QLD for a wedding and while walking along Hooker Bvd next to Pacific Fair I turned to my GF and said, "I think I hear a lumpy R32 nearby." To which she replied, "Nope, bike."
Then we saw a gunmetal 32 with the plates RAY-xxx come down the ramp and turn left onto Hooker Bvd. Sounding ever so sweet... ...and a little smokey...
Spotted a matte black 34 gtt on an early sat morning...stephen? Looks really good.
Got snobbed by a 33 4 door tonight. I get snobbed by a fair few 33's...might stop waving at you guys as my inferior 32 should not be seen amongst fine cars. :) I joke, I still wave.
Just now spotted :
White 32, looked good until the gold wheels. Not my thing. Coming out of Railway St onto South Pine Rd.
Then, Black 34 with silver mesh sort of wheels coming INTO Railway St from Samford Rd.
Also worth mentioning I've been seeing a stock looking White 33 S2 parked in Eagers along Newmarket Rd, And a White 32 (GTR?) in a side st near Mercury also along Newmarket.
Spotted a couple r33's today, one was a black s2 turning on a roundabout just off woogaroo st at around 6.20 this morning and then a white 33 a couple minutes later turning off johnson road onto woogaroo st.
Also worth mentioning I've been seeing a stock looking White 33 S2 parked in Eagers along Newmarket Rd.
It's a salesman's car. He's not supposed to park it there, but does anyway.
Look in the street behind Eagers on any Friday and you'll find mine :D
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
