spotted new gtr yesterday in southport mall bluey grey?
i was looking at his and he was looking at mine(no homo) :ermm:
wonder if he wanted to swap?
Well he should have bought a real Skyline in the first place then.
Spotted a silver 4 door 33 today in Hawdon St, Windsor/The Grange, and a black 34 with a white front bar drove past me while I was walking up Kedron Brook Rd.
Also a white 32 this morning sitting next to me in traffic on Webster Road... think I may have seen that car last Friday as well.
To the wanker P plater in the silver R34 this evening coming through Bracken Ridge onto the gateway highway.
I was not attempting to race you, i was running late for a function and was trying to get there on time, so racing up and then getting infront of me coming onto the highway was not you winning, also the half-arsed clutch kick on the on-ramp to the highway was not only pathetic but was also insanely stupid thing to do.
WARNING
to anyone in an skyline/ import around the broad beach area
there is a fat c/nt in a gold v8 statesman vt/vx model?
that likes to try to run you off the road im not sure why?
he sat on my arse for bout 1km then tried to pull up beside and merge into side
of me i booted it leaving him standing and turned then he was there again close enough i could not see his headlights
i pulled off onto the shoulder and he flew by swerving at me then pulled over and jumped out car waving his fists in anger :) as i boosted past :(
this guy is clearly a fu*ing idiot
he is a big fat terd wearing a blue collared work shirt very similar to a cabbie or bus drivers shirt
if you see him up your arse just get out the way
he does not appear to give a shit about his car or anyone Else's
if i did not have my wife in the car
this would of ended differently
:huh:
WARNING
:huh:
Simply pull over if it gets too much, call the police, take note of his number plates.
What you do (boot in anger) and he does can cause serious accidents.
There is every type of person out there, just need to not be sucked into the wrong crap.
yeah true
i only give it a boot to get away from the co&khead
ive only the had the skyline bout 2 months
still getting used to all the retards i guess
:P
I still haven't been spotted by anyone outside of our group :ermm:
I've spotted you a few times. There's a few others like yours that get around these parts. I saw one a while ago at the subway in albany creek, getting import checked with a late series FD
Hey,i'm on holidays up here at the mom,keep seeing a suncorp add on tv,is the car at the start of the add a 35 r ?. looks like it to me. :blink:
is it the one with the voice control and he is saying "step on it", etc and it keeps repeating the wrong thing? if so, then yes that is a r35 gtr.
next to a white 32gtr (was in my blue 32gtr)
on old cleveland rd coorparoo arount 9 pm or so near mcdonalds
It had close to mexican offset but was very cool
as usual the driver wouldent look at me (might have been searching for the lastest fixie bike?)
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
