It's been a spotapalooza today!
White S1 R33 on Anzac Ave, Kallangur/Petrie area this morning, chick driving, gave her a thumbs up
Purple R33 with personalised plates which I can't remember and a body kit, Gympie Rd Aspley at about lunch time. Looked like a pretty fresh paint job too.
Silver NA R33 with a P plate driving through the city, crossing Queen St
Silver V35 with body kit, Gympie Rd (or is it Lutwyche Rd there?) at Lutwyche
Another white 33 which may have waved at me while I was stopped at a set of lights in West End, didn't notice you until you were already past me as my attention was elsewhere, I didn't think the car behind me was going to stop
Spotted a bright Red R33 yesterday afternoon around 6:30pm with body kit, turning right onto Smith St (towards the M1) from the street Gold Coast Griffith Uni is on, only caught a glimpse but it looked sweet.
And later that night around 9pm spotted a black R33 heading along smith street to the m1, no spoiler. Had a blonde in the passenger seat. Pulled up at a set of lights next to another white R33 so it was 3 lanes of R33's at the lights next to the Caltex. Both very nice. :D
Silver Nismo badged 32 GTR on Albany Creek Road about an hour ago. 277-JTZ or JUZ or something. Damn nice looking car. Shame you drive like an absolute fuckwit and do 80 through 60 zones, even faster through the 70 zones and change lanes without indicating and help to give us all a bad name.
Edited by Isola
spotted today within the hour of 4pm
Red R34 four door + white R32 gtst on henty drive - redbank plains
white R34 2 door redbank plains road + maroon R33 parked at woolies R.Plains
I've never seen a red FOUR door 34! That almost sounds like it'd be awesome.
Spotted vandit this morning on klump rd. was coming out of gym.
hey sexi lol finally got spotted.. cant forge the day blew my g/b lol ...
spotted black 35GTR spec V with plated 346.LPZ ar griffith uni nathan last nite
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
