lol i dunno who would raise it though looks stupid that high
yer it does ey... i asked the guy when i was buying it if he goes on cruises and stuff and he said back in his asian voice " Cruisess.. what do u mean, cruises". lol..
O well.. least it looks schmik now.
Ima cruisin...
DRUZILLA, I drove ur 32 about a month before i bought mine. I was in the process of importing thru somebody who stuffed me around endlessly, and trying to get my money back off of him at the time. That was the first and only GTS4 i have driven. Have you had any problems with it? Did u manage to knock the price down abit? He didnt have it well presented to sell when i looked at it on that sat avo.
I must admit it is looking the goods now (that wing on the back was ugly), and it sounds like u are going to town on it with mods too :D I have different mags on mine to what is in the avator
The attached image is the before photo. (when we were looking at it a while ago)
I am quite happy with it.. I am putting a fmic and rest of the exhaust on this weekend too
looks like this now
I thank you soo very much for having taste and removing that huge oversized novelty wing that did nothing.
Good work ;)
I must admit it is looking the goods now (that wing on the back was ugly), and it sounds like u are going to town on it with mods too ;)  I have different mags on mine to what is in the avator
yeh your mags look the goods
Yeh got $700 off the marked price.
No major problems... Just found out the other day that i have a faulty knock sensor. I dont no how serious that is in regards to price..
LOL, it wasnt very well presented was it.. There was shit every where
Oh No!
gunna have to change jobs now :D
Heheh!
sall good mate, so lets talk about discounts ;) just kidding
um, black 4dr 33 on the espy yesterday arvo, female driver and passenger from memory, looked neat tho,
very weary of black 4dr skylines theres at least 2 4dr 33s i know that are rather quick :)
Hi...everyone out there....I'm Lee. You may have seen me around.....I own a four door just like 4doorz. Thought it was the only one...but saw 2 others (damm...) BUT mines the 5 speed turbo one so far....The Ford blue print colour with the GTR front, sideskirts and rear quarters and a "DMD" sticker on the front windscreen.Slowly working on it...but no dosh, still paying it off.
Say "hello" if you see me cruzin...
sall good  mate, so lets talk about discounts :D just kidding
James if you are after parts give me a call, I will hook you up with a good price ;)
In fact I may think about doing discounts for all QLD SAU members (once the club is up and running)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
